Should I vent my roof system or not?
![](https://secure.gravatar.com/avatar/6deef2b043ede3589fd4b84a6f8de0b8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
A well known SIPS panel manufacturer that I am currently dealing with has said they will not warranty their structural panel without a ventilation layer if asphalt shingles are installed directly onto the structural panel. I have recently designed and am currently building a house incorporating what I have come to believe are realistic energy conscious features ie. ICF foundation, insulated basement slab, air source heat pumps… I specified and installed the Adventech zip roof panel w/ tape with the intention of building a hot roof consisting of closed cell insulation with no venting. Is there any worry to continue with this? I am thinking that the watertight layer/ and tape adhered to the osb panel may act like the glue layer in a SIP panel. I am also entertaining the idea of using accuvent then closed cell to create a ventilated roof roof deck. All feedback is welcome. I have actually built using both methods including large depths of open cell.. I also already installed soffit venting because I am waffling back and forth.. The project related to this question is located in a coastal climate less than 2 miles to the ocean in Southeastern MA. We have built 2 Energy Star qualified homes in the past 3 years.
Mark,
Most shingle manufacturers require venting if you want to keep the warranty, but many builders ignore the requirement, because shingle warranties are rarely useful.
You can vent on top of your sheathing layer if you want, by adding eave-to-ridge 2x4s, installed on the flat, either 16 inches o.c. or 24 inches o.c. Then install another layer of roof sheathing.
