Should I do a birdsmouth cut for low sloped (tiny house) shed roof?
![](https://secure.gravatar.com/avatar/450b7765118966a516aa0f1b4402f975?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fg.png&r=g)
Hello,
We’re getting close to framing my roof for my tiny house on wheels. The roof is a low sloped 2:12 pitch. There will only be 3-6 inch eave/overhang.
Should I do a birdsmouth cut for this? What benefits does this provide? If not, what method do you recommend that I do and why?
Thanks!
Grey,
Yes, you need a shallow bird's mouth. These days, most builders also use a hurricane clip (Simpson clip) as well.
Cheers.
Grey Wolf,
There are two benefits to including birds mouths.
- It increases the bearing area so the corner of the rafter doesn't crush under load.
- It provides a horizontal bearing surface so all loads are vertical. Witpout the horizontal surface you also would have loads trying to make the rafters slide off the roof.
