Should I consider Structured Plumbing in 4500 sq. ft. house?
![](https://secure.gravatar.com/avatar/34c5ddd51b1ccfb5e45e8d66f45f89eb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hello and thank you for looking at my question. I hope someone can explain this to me in laymen’s terms.
I’m building a 3 story, 4500 sq ft house that will have 6 bedrooms and 7 bathrooms. I want to make sure the plumbing is designed so I have minimal water and energy waste getting hot water to the fixtures in each bathroom but I don’t know anything about plumbing design. It seems to me the best approach would be to have two separate systems (think duplex) since there is a center hall and most of the bathrooms and kitchen are on one side of the house. However, I can’t find any examples where this has been done, perhaps because it’s too expensive?
I’ve been reading about structured plumbing but I don’t really understand the concept. Not surprising since I’m not a plumber or builder, just a homeowner. So, I’m asking the professionals here. Is structured plumbing the way to go and if so, how can I learn about it? Thanks in advance for your help!
CherylAnn,
"Structured Plumbing" is a brand name for a system that uses a circulating pump. For more information on this brand name, see Structured Plumbing®.
If you are interested in conserving hot water, you might want to read these GBA and Fine Homebuilding articles:
Hot water circulation loops
Waiting for Hot Water
Hot-Water Circulation
All About Water Heaters
Cheryl
I think you are referring to the use of a plumbing manifold, with separate branches to each fixture or appliance (sometimes called a home run system). Take a look at this for a description:
http://www.finehomebuilding.com/2009/03/02/three-designs-for-pex-plumbing-systems
If so, I can wholeheartedly recommend it, with caveats. We added a manabloc (TM) system in our basement bathroom, directly linked to the instant hot water heater. The upstairs bathrooms are directly above, so 85% of our water use is concentrated in one place.
http://www.viega.us/4741.htm
I said a caveat as hot water takes a long, long time to get to the laundry and dishwasher at the other end of the house, so they end up heating electrically sometimes. With hindsight I would have plumbed the laundry and kitchen on a recirculating loop with its own smaller Manabloc. However, this was added complexity and cost I couldn't justify at the time.
One last point: my plumbing inspector does not like the smaller 3/8 PEX and wanted everything in 1/2" or bigger: a crazy waste of water.
Hope a real plumber can chime in!
Andrew
CherylAnn,
If you are still visiting this post to read new comments (I'm not sure that you are), here's the scoop: a circulating pump is one way to reduce the wait time for hot water. Circulating pumps can waste a lot of energy unless they are controlled by a switch located in the remote bathroom.
Home-run plumbing systems (systems that include a manifold) are different from systems with a circulating pump. You can have a circulating pump with or without a home-run (manifold) system, although it most cases you don't want a home-run system if you are installing a circulating pump.
In a house like yours, two water heaters may make sense.
