Shed roof insulation
![](https://secure.gravatar.com/avatar/1849900d1ddd2e46fed1bd1ce00c24cc?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hey – I think I’m on the right track here but just need some confirmation before I go down the wrong path. So the previous owner added an addition on the back of the house with a shed roof. This caused serious hot/cold since it was done with open soffits and it just ran right up the side of the house. I am trying to tighten up the home as I go. I eventually want to have a continuous layer of 2″ rigid foam on the exterior of the house – we live in Zone 4A and I believe I remember hearing on a BS+Beer show 2″ of rigid foam is enough to keep the dew point outside of the wall assembly on almost any climate zone.
Ok – so I had a roof done about 1-2 years ago and had the contractor put a cor-a-vent like system to allow the roof sheathing to channel air. I then installed polyiso baffles to channel the air from the soffit to the roof vent. It gets a little tricky because there is a bulkhead/soffit where the original house and addition meet which has HVAC running through it. So even if I blocked off the exterior soffit, the sheathing behind the shed roof would still heat up to the temperature of the shed roof “attic” and channel through that interior soffit/bulk head. I basically blocked off all I could with 2″ rigid foam and then ran 2″ rigid foam up the sheathing (the green lines indicate where I put rigid foam). Next I am going to fill the joist bays with mineral wool.
I am just looking for some feedback/confirmation that I am not going to cause some unforeseen issues with dew point/amount of foam.
Any advice is helpful – thanks in advance!
