Shear Wall Sheathing Blocking IRC
![](https://secure.gravatar.com/avatar/b278e7cbce34d806dc23b6b4af5a28de?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
For exterior sheathing code, can the blocks for edge fastening be installed edge up leaving the wall cavity open and providing a larger nailing surface?
For shear wall bracing, I am not aware of a code requirement regarding orientation, and my carpenter's intuition says that it shouldn't matter. But it's not something that I can recall coming up on plan reviews or inspections; it may matter, at least in some locations.
Some people combine shear wall bracing/panel bracing with a fire stop. Not a code requirement but a construction practice.
