Secure Vertical XPS at Foundation Stem Wall
![](https://secure.gravatar.com/avatar/675d73deb42355324e6bc666f6116ded?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
Hey All,
I’ve decided to have the excavation company clear out the garage’s slab below grade to add XPS for radiant tubing. The XPS is only reaches about 6 inches in depth. So, do I need to worry about it floating out of the conc.? Should I secure it somehow? see atch’d image.
idahobuild,
I would glue it to the concrete with foam adhesive so it doesn't move during the pour.
thanks Malcolm - I'll see if I can track one down that will work at the temps we're dealing with.
idahobuild,
Yes - I guess that does complicate things right now.
