Sealing RIM Joists
![](https://secure.gravatar.com/avatar/75cf4ab8f16f2a3191f6a2f348fa666b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Attached is an energy audit done for my Single Family home. I have a cold home and I am getting things in the report fixed. This question is about the basement air leaks from the Rim Joist (Pages 6 and 7 of the report). Since then, my basement has been mostly finished (the walls are up), so I have no easy access to Rim Joists. The basement is cold and the thermal imaging shows air leaks along the Rim Joists. I can also feel cold air coming out of the outlets and switches (the switch plates are not installed yet).
1. Is it worth cutting a foot of ceiling drywall and sealing the rim joists? I am getting estimates like $6000.
2. What is the easiest way to get access to the rim joists? Any guidance would be helpful.
Thanks
We did this and our basement is now the most comfortable room in the house. Maybe you can reduce the cost a little by having the spray foam guys hit the top plates and other penetrations in the attic while they are there. Those 2 part diy spray foam kits are also perfect for this type of air sealing.
@mgensler - If I understood you right, you suggest that it is worth the expense of ripping out the drywall, exposing the rim joist and insulating the rim joist. Right?
If so, should I just spray foam the rim joist between the floor joists. How many inches? Does 2 inches sound good or should I seal with spray foam, put foam board and the batte?
Thanks in advance
Dabbi,
You may find this article useful: https://www.greenbuildingadvisor.com/article/insulating-rim-joists
