Sealing gaps in fieldstone foundation
![](https://secure.gravatar.com/avatar/0e8f986c3d8cc8bb195b05017e03419c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I have a 1900 colonial home in MA with a fieldstone/rubble foundation.
While air sealing recently, I discovered one area of the basement near the basement door, which has a 1/2-1″ by 4 ft gap where the mortar has crumbled away over the years. Is there anything I can do temporarily to seal this up until I am able to repoint this come spring/summer?
I could spray foam it, but it would probably be a huge headache to remove the foam when it comes time to repoint the stone. Would backing rods and caulk be a better option?
Temporary till summer? Two old t-shirts stuffed in there should perform admirably and remove easily.
Tape might outperform t-shirts.
David,
If you want to buy 1-inch backer rod, they make it. It costs more than an old T-shirt, but it will probably perform better.
Here is a link: One-inch backer rod.
