Sealing chimney chase
![](https://secure.gravatar.com/avatar/25a68c69ef9b8b040d2c21644802d0c7?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
The chimney is used to vent the oil boiler, would it be ok to seal the chase leading to the attic? Also would it be acceptable to seal the hole from the basement as well or is that a a hard no?
