Sealing a below-grade foundation wall penetration
![](https://secure.gravatar.com/avatar/2969e7d5672be2932e736a8732a5f877?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
What are the current acceptable approaches to sealing pipe penetrations through a below-grade foundation wall?
I’ve heard
1. high viscosity polyurethane
2. Low-expansion urethane foam + boot outside (fine homebuilding)
3. Other various boots
I will have a dimple membrane on the exterior.
Thanks!
Rossn
Ross,
The dimple mat (if it is properly installed and integrated with a good footing drain) will take care of the hydrostatic pressure. If you use a high-quality caulk or European tape, you should be fine.
Also slanting the pipe so water is channeled outward.
Generically, I'd favor seals that still seal with high movement - compressed foam gaskets, rubber, maybe bentonite in some special cases.
Pouring a sleeve into the foundation for all penetrations is the way to go. schedule 40 PVC or ABS sized to accommodate the pipe and some sealant or a gasket. That way you aren't trying to seal the pipe to concrete.
Thanks, guys -- all good ideas and information. Sika recommended one two-part product, and Titebond recommended their weathermaster ultimate MP, which I'm finding to be a very versatile adhesive+sealant that isn't to toxic and they report bonds well to almost everything. Since I already have some, I think I'll use that. Good ideas on the slope, sleeve, and tapes.
The best products I've seen so far . Have not had one issue with these .
https://www.youtube.com/watch?v=hWMKCfPemf4
If GBA readers don't want to be held in suspense as they watch a video, the product that Richard is talking about is called Link-Seal. It is manufactured by GPT Industries.
Here is a link to the relevant web page for this product: Link Seal modular seals.
Does Dupont Flex Wrap work below grade? We need something faster than we can get euro tape.
