Sealed gas see-through fireplace to outdoors
![](https://secure.gravatar.com/avatar/8e2c1240717a0f71fbe9a56b2a5bf3a0?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
My wife loves a nice fire and wants a fireplace in our new home. One model we are considering is see-through, which would allow us to have the fireplace in the great room and the screened porch. This unit does not have a flue, since it exhausts to the outdoors from the top of the outside glass.
So, that would mean we have a metal connection from the outside to the inside with no thermal break. Although the glass is double paned (one inside and one outside), the 2 ft. separation pretty much negates any R-value.
It’s obviously not a good idea, thermally, but what can I do to insulate around this and air seal it more effectively, if she decides this is what she wants?
It looks like I can put insulation underneath, within a 1/2 of the sides and 9.5″ from the top. I need ideas on what will not melt or deform over time in this space.
Here are the specs: http://downloads.hearthnhome.com/installManuals/2368_970.pdf
Thanks,
Norman
CZ 3A
Norman,
I can't answer your question, but I did find a number of product reviews on Houzz (https://www.houzz.com/browseReviews/heatandglo/heat-glo-fireplaces-designed-to-inspire). From what some owners are saving, this sounds like a problematic product. Plus, I wouldn't want combustion gases venting into the same space where I'm sitting--even if that space is outdoors. Just seems like a not green or healthy design.
