Seal Flex Duct Connections With Fire Block Spray Foam?
Is it acceptable to seal flex duct connections (at supply plenum, ceiling boot, where main supply lines branch into multiple lines) using a can of fire blocking spray foam? Thank You.
Randy,
It's acceptable, but canned spray foam may not provide a dependable and durable air seal. Either high-quality foil HVAC tape or mastic is usually a better choice for air sealing duct seams.
If you do end up using spray foam, a thicker layer will provide a better air seal than a thin layer.
