Roofing Underlayment as WRB on Side Wall
![](https://secure.gravatar.com/avatar/4b2b66e837149550301c4978c6d9194e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
What are the problems, if any, with using Roofing Underlayment on the side wall as a weather-resistant barrier, provided that the product has the desired physical characteristics (perm rating, etc…)?
J.L.,
All building codes require that a layer of asphalt felt, a roofing underlayment, be installed on walls as a water-resistive barrier (WRB). Other products, including plastic housewrap, have been approved as acceptable substitutes for the code-required layer of asphalt felt.
More information here: All About Water-Resistive Barriers.
Whatever you do, don't install synthetic roofing underlayment as a WRB on wall. Most synthetic roofing underlayments are vapor-impermeable. That's bad.
