Roofing question: Do I NEED 5/8″ plywood decking under a 50-year steel roof?
![](https://secure.gravatar.com/avatar/140b25e71e7e12654613b3684bdd0270?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Specs:
House 6:12 pitch, garage 3.5:12 pitch
Trusses 24″ OC, 2X6 top cord (solar ready). Climate zone 6A, mid to low snow load.
I’ve already moved off the 7/16″ OSB decking that is on the plans, and have temporarily settled on 1/2″ plywood decking for the roof. Roofing contractor said this would be much better for the screw holding power (using click-lock standing seam panels, 26 gauge, 16″ wide). Now the question is would I see any benefit over time going to a 5/8″ plywood roof decking? The cost is incremental vs 1/2″ ply (let’s call it 1k), but it all adds up, and if 1/2″ is plenty i am content leaving it at that. Will 1/2″ ply sag over time on 24″ OC trusses, and if so will 5/8″ provide any benefit for this over a 50 year life span? Assume venting will be more than adequate (full length ridge vent gable roof, full vented soffits).
Mai Tai,
No you don't need 5/8" plywood. It's better but not necessary. The most noticeable difference between 1/2" and 5/8" is when you walk the deck before installing the metal and feel the flex if you stand on a horizontal seam. Once the roofing is on this disappears. There is no reason to believe the plywood will sag over time.
Having said that, I've suggested and used 5/8" on two houses, and liked the feel of both the deck and the way it held fasteners. But I think it falls in the category of upgrades which are nice, but over time makes no discernible difference.
Mai Tai - use plywood clips between the 1/2" sheets in between the trusses. Good stiffener for edges, though may not matter once metal roof is on.
Kevin,
I wouldn't use H-clips under metal. Too great a chance they get slightly misaligned and telegraph through. The metal roofing fasteners end up doing the same stiffening of the plywood edge.
Using H-clips really slows down the sheathing. Do you use them where you build? I haven't seen them here on a house for years.
