Roof ventilation – is it advisable to exceed code minimum
DBars | Posted in GBA Pro Help on
If I well exceed the 1/300 nfva minimum set out in R806.2, can there be any issues with this?
I have 40% at the ridge and 60% at the eaves (split between two eaves of a gable), but my ratio is approx  1/75, roughly 4 times more nfva.
Thanks,
Daniel
  1. Malcolm_Taylor | | #1
    Daniel,
    I can't see any downside to more ventilation. Maybe in hot, humid climates?
    BILL WICHERS | | #2
    There is some advantage to having more intake (soffit) than exhaust (ridge) ventilation, since more intake means less issues with a depressurized attic and it's resulting increase in stack effect within the home. The only place I can see venting to pose problems is in areas subject to high fire risk.
