roof insulation retrofit
![](https://www.greenbuildingadvisor.com/app/uploads/assets/avatars/23530-avatar-1550116110-100x100.png)
A good friend of mine is having his roof redone soon and would to insulate it. The assembly from seems to be 2×6 ceiling joists with 2×8? rafters above that.
What we know..
A few rafters need to be replaced or sistered accordingly.
2×6 ceiling joist + spacing between joist and rafter + 2×8? possible rafters
4 Ventilation openings , 2 On the north side and 2 on the southside.
Since he will be replacing the sheathing we will have unrestricted access to the ceiling below.
My original plan was to box out can lights and purchase a spray foam kit and air seal and spray 2 inches topside of the drywall then blow in cellulose or rockwool up to vents.
option 2 was to caulk and spray foam all cracks and gaps in addition to boxing out cans, assuming drywall is a sufficient air barrier with proper sealing topside. blow in insulation in the same manner.
option 3 would be to blow in insulation up to top of 2×6 then staple down an air barrier such as intello plus or 6 mil poly. Followed by some more blow in insulation up to vent openings.
All 3 would be superior to what he has now. I remember reading here that cellulose is a pretty good air barrier on its own with ample amounts. I this plausible just blow in 10-20 inches and call it a day?
Also the vent opening seem a bit frugal to me. For proper air flow and to truly keep this a cold roof will I need to add a few more?
Just preliminary thoughts but eager to hear from the community on this one.
Btw we are in chicago climate zone 5
Raul
