Choosing Between Two Roof Assemblies
![](https://secure.gravatar.com/avatar/1da902b62eef888f571e7a85405c8162?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Hi. I am in zone 4a (Nashville area).
I would appreciate a sanity check on my shop building/in-law suite building. (Pic below)
Questions:
- If I go with the polyiso over the roof, how do I install it?
- Do seams need to be taped?
- What goes on bottom layer and what goes on top layer?
- My 2″ thick polyiso has a white skin on it. (Pic below)
- My 1.5″ polyiso has a black felt (Pic below)
- Is it foolish to only have 3.5″ of foam and I should go with vented attic and blow in cellulose?
I am weighing two roof assembly options:
- Blow-in cellulose over ceiling with vented attic
- 3.5″ Polyiso on top of OSB
I have the recycled polyiso on hand. The cellulose will be about $1400 (very affordable)
The polyiso route will give me a much more spacious feeling with 5 extra feet of space to peak. The trusses are 8ft OC (post frame).
The cellulose will give me a much higher R-Value
I will be making a pretty air tight assembly. Sealing with 3M 8067 and Dymonic 100.
I also have 2″ of recycled Fomular 250 25psi foam board under concrete.
Thank you.
-Mike
Hi Mike,
My reading on GBA suggests that rigid foam on the roof is normally installed as a sandwich (sheathing + foam + sheathing + roofing). If you decided to go this route, you could combine your 3.5 inches of polyiso with air permeable insulation applied inside against the sheathing. (See https://www.greenbuildingadvisor.com/article/combining-exterior-rigid-foam-with-fluffy-insulation.)
Going with a vented attic and cellulose would probably be a lot easier and cheaper. But you'd want to avoid putting the HVAC equipment or ducts in this space.
