Seeking Opinions on this Roof Assembly
![](https://secure.gravatar.com/avatar/e776db1438112dd5c2437420ed3c961e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Hello,
I’m building a new house and looking to do unvented attics for the main house and vented attics for the garages/back porch areas.
I’m currently thinking about the roof assembly and what insulation to use in the attic. It seems like the goals would be to implement: radiant barrier, rigid foam insulation on the exterior, and airtightness, & good weather proofing.
After doing some reading here and reviewing some products, I’m wondering if something like this makes sense. I haven’t priced out anything, still in the early stages, but curious to see what thoughts you all have before I get too far into this:
I’m in Climate Zone 2. Houston, TX.
– open cell foam in rafters
– decking (Huber Zip sheathing 5/8″)
– Insulation/Radiant Barrier (Atlas ACFoam CrossVent). Would this go directly on top of the zip? Sounds like you can add a radiant barrier to the underside of the OSB facing the air gap.
-finally, the roofing products. thinking about just shingles.
Looking to hear your thoughts. Thanks
I’m going to give your question a bump. You didn’t say if you are planning a cathedral ceiling or not but Martin Holladay posted an article last week that might interest you. Five Cathedral Ceilings That Work.
