Roof assembly questions
![](https://secure.gravatar.com/avatar/6907c33c6327cdb2060c775abbdea50f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hey All,
I read all the roof insulation articles but want to make sure i’m understanding correctly and that my plan works:
I have an old cabin that I moved that does not meet code in zone 6b. The current roof deck is – t&g, roofing felt, then a weird cross cross of 1x with 4.5″ rigid foam stacked inbetween (with some sections having fiberglass insulation inbetween). There is no rot so this roof assembly worked for 30+ years (I assume because there was no insulation on the interior?). I am thinking of ripping the current roof off down to the T&G, applying a peel and stick membrane, and then stacking the entire r-value of the roof with rigid foam, 2×4 on flat (1.5″), then metal roofing. The reason i’m thinking of this path is the second floor ceiling height is already fairly low and I don’t want so sacrifice headroom + I like the t&g look. Problems: It looks like I need 12″ of rigid foam to meet the r-49 requirement which seems crazy thick. It would mean new fascia boards (or I can potentially span the gap with really long L flashing to cover the foam?). I’d like to re-use the fascia as its in nice shape and matches the aged look of the cabin. I am also a bit confused on the alternative u-factor calculation that could potentially reduce my insulation thickness. I’m on a tight budget as the roof is just the first of an entire restoration. Since I won’t have any framing, and the rigid foam will extend to the end of the eves past the walls, can I get away with going thinner on the insulation? the only connection I will have is the screws going all the way through so the total assembly insulation value should be better than with other methods right? Thanks for your help.
Check your local code. With continuous poly-iso and the U-factor method(.026?), I think it's more like 6". Which could be tapered down over the eaves.
