Tiny House Roof Assembly
![](https://secure.gravatar.com/avatar/b77f258cfd6d29bff6a44c3f7539f0a9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Thinking about the roof assembly for my tiny house on wheels. Height is limited, but I think I can do about a 10″ thick roof. I was going to do a 2×6 rafter with Havelock wool in the cavity (R19) with 4 inches of some combination of polyiso, xps, or rockwool above the sheathing. BUT I have 2×4 walls so might be easier to do a 2×4 rafter and just get extra of the same R13 wool for the wall cavities with 6″ of some combo of iso/xps/eps/rockwool… What combos would you all recommend?
Also this house will have plenty of heat but no AC so I am concerned about keeping things cool in the summer, especially in the loft. The foil-faced poly iso sounds good for that, but from what I am reading I need a membrane between any outsulation and the actual roofing material? I found a vapor permeable staple on foil pretty cheap — could I use that on top of whatever membrane I use? Also how would I ensure the airgap necessary for the foil to work? Furring strips just like on my wall assembly?
I’m in climate zone 5, maybe moving the house to climate zone 4 later in life.
Roofs are so confounding….
I’m giving your question a bump. While you wait for opinions, check out this Q&A thread: Vented roof assembly for tiny house.
That was definitely an interesting read! Thank you!
