Rockboard [mineral wool] or polyiso?
roygoodwin | Posted in Energy Efficiency and Durability on
I’m planning a new house. I’ve been thinking in terms of 2 3/4″ of polyiso on the exterior of the walls. However, I’m now thinking that dense rockwool board *might* be better at least from the standpoint of the wall being able to dry to both the outside & inside. I kinow I’d be giving up some r value, but perhaps I could just up the thickness ? I’m in climate zone 4 Western NC in the mountains. Probably using zip sheating under either insulation board.
  1. GBA Editor
    Martin Holladay | | #1
    Roy,
    To read the accounts of two projects with mineral wool insulation on the exterior side of the wall sheathing, check out these articles:
    Installing Roxul Mineral Wool on Exterior Walls
    Wrapping an Older House with Rock Wool Insulation
    You might also want to read:
    Installing Mineral Wool Insulation Over Exterior Wall Sheathing
  2. LucyF | | #2
    Roy,
    I'm in Upstate SC and did exactly that on our new house. We put 2" Roxul Rockboard wrapping the entire exterior. I chose Rockboard, because I could not easily get Comfortboard. The big box stores have to order Roxul Comfortboard in large pallets and wait for a full load before they order. They estimated 6 weeks for a shipment. I got Rockboard easily from ATS Acoustics online in less than a week. I think Rockboard and Comfortboard are the same product. Here is the GBA post talking about the 2 products:
    https://www.greenbuildingadvisor.com/community/forum/green-products-and-materials/28137/roxul-rockboard-60-vs-comfortboard-exterior-insul
    Patrick Walshe's blog, http://agreenhearth.com, has a good discussion on using mineral wool.
    My blog has some information as well. http://greenvillegreen.blogspot.com/2013/10/cozy-mineral-wool-sweater-on-house.html. You could hit the mineral wool insulation under labels and see the posts on how we used the Roxul.
