Risk of exposure to ZIP OSB off-gassing
claythonmclaw | Posted in General Questions on
Based on the “Getting Insulation Out of Your Walls and Ceilings” article (and similar to the PERSIST/REMOTE wall design), in my plans I’ve moved rigid insulation to the outside of my air barrier (which is at the sheathing layer) and the left stud bays empty.  For an interior finish I’ve used two layers of white pine with overlapping seams on the interior of the studs.  The sheathing I’m using is Zip System OSB (taped).
My concern is this: A couple of weeks after putting up the zip system boards, I’m still smelling the zip system through the white pine.  I’m guessing the smell will subside over time but I also have health concerns: if I’m smelling it, surely I’m breathing in chemicals that are in the zip system material.  I cut the zip boards outside and was careful to wear a P100 respirator while cutting and fastening them (which hopefully worked–I didn’t smell the material at all while using the mask).
I tried looking into this a bit and from what I can tell I don’t really have any reason to be concerned, especially if it’s going to be a while before I move into the structure.  My “question” is really whether or not I’m interpreting the data correctly and not missing anything.
First, it seems the out-gassing chemical of concern is formaldehyde (at least this is what the resources I’m reading seem to focus on).  Huber uses phenol formaldehyde in its products instead of urea formaldehyde (https://www.huberwood.com/uploads/documents/technical/documents/Formaldehyde-in-AdvanTech-and-ZIP-System-Panels-Technical-Tip-Roof-Wall-and-Subfloor-ZIP-System-and-AdvanTech.pdf) which tends to out-gas less and subsides to undetectable levels over the long term according to https://www.roseburg.com/UserFiles/Library/APA_Tech_Bulletin_on_Formadehyde.pdf
According to APA Technical Note J330
(“Formaldehyde and Engineered Wood Products”
https://www.apawood.org/download_pdf.ashx?pubid=2962e0a8-596d-4df7-96e0-cdeebade8647), the emission level of 0.2 ppm under the ASTM E1333 Large Chamber Test method appears to be the limit specified by the US HUD safety standard, and typical plywood and OSB products range between 0.01 and 0.04 ppm.  Zip System OSB ranges between 0.04 and 0.05, so it’s on the high end compared to other products but still well below the limit https://www.huberwood.com/uploads/documents/technical/documents/Safety-Data-Sheet-Wall-Roof-and-R-sheathing-ZIP-System.pdf
All of this taken together leads me to think that if the structure is left to out-gas for a while I don’t really have anything to be concerned about.  But perhaps I’m missing something or interpreting the information incorrectly–I’m prepared to take all of the OSB down if they’re a health risk (though I don’t know of a good alternative–there’s Purebond but that’s not intended for structural use)
  1. GBA Editor
    Brian Pontolilo | | #1
    Hi Claython,
    This is the first time I have heard this concern specifically with OSB sheathing, but it is a common question, just replace OSB with spray foam, roof underlayment, etc. The first thing to do is ventilate the house for a bit and see if the odor goes away. If you are particularly sensitive to it and it seems to persist, you could take down the wall paneling and install air-tight drywall on the interior. This is probably easier than taking down the sheathing and you can reinstall the paneling over the drywall. Some people have also mitigated these issues by slightly pressurizing the building. First, just give it a few days.
    BILL WICHERS | | #2
    I agree with Brian. The best course of action is to just wait a few days. Just about everything has a bit of a smell when new (fresh lumber, new cars, fresh basil, etc). Smell as a sense is detecting airborne chemical compounds from any of these. It’s not usually an issue unless the concentrations are high. Most of the off gassing occurs when the product is new, and rapidly drops to much lower levels.
    Providing air flow (moving air) will help to speed up the process. Cheap box fans are good for this.
  3. claythonmclaw | | #3
    I appreciate the responses. I will give the building some time to air out
  4. steven765 | | #4
    Curious if the smell went away? Because we just got advantech sub floor dropped off, it smells like crazy. Even after 2 weeks it's still off gassing something in the attic. It's now permeating down into the living spaces.
