Rim Joist Insulation
![](https://secure.gravatar.com/avatar/68a20044abf25a5405dc2bbb63396ba5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hello
first I would like to thank the members for this valuable site, I have learned a lot here.
– My question is referring to the rim joist area between 1st floor and 2nd floor.
– I am in zone 6
– Just completed framing and I have installed 3″ comfortboard on the exterior.
– I do not have any hangers in this area so no significant metal that would get cold.
– Everything I have read regarding rim joist says to spray foam.but i think this advice is more so for renovation or houses with no exterior insulation.
– My question is; would using R24 rockwool within the cavity of the rim joist be enough or is there a reason why I should not. As I am trying to avoid using any spray foam in the living areas of the house.
thank you
I’m doing exactly what you were doing. We are in Zone 4.;We have 1.25” exterior mineral wool on the outside and I do not want to do the spray foam on my rim joists. What did you end up doing? Thanks.
