Rim joist insulated with vermiculite
![](https://secure.gravatar.com/avatar/ba7cadbf422f048eb27b43dc40ed3176?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hello, my basement rim joists are insulated with vermiculite loose fill insulation, I believe it’s original to the house that was built in the 50’s. Climate zone 6/7 in the US so very cold. I’m not too worried about the asbestos potential as it’s encapsulated by a 2×8 on the interior. I don’t want to disturb it either. My plan was to add rigid foam to the rim joist but upon further investigation I found it was already insulated. The Rigid foam I planned on using was John manville’s CI max polyiso with aluminum facer because it’s fire rated for leaving exposed.
My question is should I still add rigid foam or not? I’m worried if I cover it with foam any potential moisture getting in wouldn’t dry to the interior anymore. Add in that vermiculite is used in gardening for its moisture holding properties. I also want to eventually do exterior insulation, probably foam EPS panels which would cover the rim joist area from the outside.
How should I handle this without removing the vermiculite?
Thanks
