Rigid Foam Insulation for Walls and Roof
![](https://secure.gravatar.com/avatar/d54dd52e1391bdcee3050aa5549c40aa?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hi all,
I have been playing around with a few ideas to adequately insulate my Cape Cod style home. I’m wondering if there’s an issue with having 1” polyiso on the interior of the walls (dense blown cellulose underneath), and polyiso and EPS above the sheathing for the roof (with cellulose batts between rafters)? I’ve read through as many of the pertinent articles as I could find and know both are doable independently, but haven’t seen anything about them used together. I just want to make sure there’s no issue with the walls drying to the exterior but the roof to the interior.
Thanks,
Chris
cgmorgan,
It will work fine. Neither cares what the other's drying path is.
Thank you for the confirmation Malcolm.
If I may, a related follow up to that situation: winter is upon us, I have a completely gutted second floor (in Montreal zone 6 to boot) and all roofing contractors are solidly booked until next spring. I’d like to get all of the interior work done over the winter and redo the roof at the earliest possible moment, but that would leave me with about 6 months of the cellulose batts in the rafters in direct contact with the sheathing without exterior rigid foam. I know this is not ideal, but given cellulose’s handling of moisture and proper air sealing, is it doable?
Thank you,
Chris
Chris,
I don't know. My gut feeling is it will be fine - especially if you aren't generating a lot of moisture. But I haven't worked in a cold climate like Montreal for over 30 years - and when I did, I didn't know what I was doing. Hopefully someone with relevant experience will chime in.
