Ridge or roof vent for differing slopes
![](https://secure.gravatar.com/avatar/385f8b3fe48a577f654bad0f5f5c2519?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
I have a roof that is a 2:12 on one side and 4:12 on the other. Am I better off just using those mushroom style vents near the ridge, or an actual ridge vent?
im asking because I can’t find a ridge vent that accomadtes my roof with differing slopes on either side. They say the 2:12 is not steep enough or they don’t fit differing slopes, etc.
any recommendations here?
i currently have a standing seam roof, which has a minimum pitch requirement of 3:12 – so when I re-roof I am probably going to use normal shingles or something like it – if I can at 2:12…
thanks.
Kevin,
I use two different suppliers of snap-lock metal roofing (Westman Steel and Westform Metals) Their panels and trim are almost identical, but one allows their use down to 3/12 and the other to 2/12 - so I wouldn't dismiss replacing your roof with a new metal one.
I don't like applying either metal or shingles to a roof slope that low, but if I had to choose I'd prefer metal - and a metal cap can easily accommodate the two pitches.
Kevin,
One other factor to consider: a 2/12 roof is a low-slope roof, so the usual methods of providing a vent channel don't apply. For more information on low-slope roofs, see "Insulating Low-Slope Residential Roofs."
Hi Kevin -
Be surprised if any roof cladding or ridge vent manufacturer will warrant vent systems for less than 3:12 pitch; just too much potential for non-gravity directed bulk water movement (i.e. a leak or leaks). Also, at that pitch, just not clear how much actual air movement venting provides.
Peter
