Revive solar thermal
rhl_ | Posted in Mechanicals on
I recently had my spacepak air to water heat pump installed.
Having this system makes me immediately want solar thermal to offset the electricity.
I know solar thermal is really really dead but can it be revived?
    BILL WICHERS | | #1
    I think the consensus here has been that photvoltaic (PV) solar has dropped so much in cost that it now makes more sense to install PV systems than it does solar thermal systems. I don't even know if you can still buy new solar thermal collectors anymore. Your best option here might be to run an electric resistance water heater on a PV system, then use that water heater to run a radiant heating system. Some water heaters are actually rated for space heating systems like this. You basically "charge" the water heater with PV electricity when PV power is available, then use the hot water as heat storage, drawing it off as needed. This is a bit simplified, but basically how those systems operate. PV can also offset your home's regular electric use with a grid tied system, making such systems more versatile than solar thermal systems.
  2. rhl_ | | #2
    I have an air to water heat pump that serves heating cooling and DHW.
    I have 8.6kw solar pv that does not cover my entire roof but gives me 130% of my pre heat pump energy usage.
    I'm going to add more solar but since the energy it generates is exclusively to offset the heat pump I wonder if a PVT panel would make sense as it could tie in directly to my existing glycol air to water system.
      DCcontrarian | | #3
      The problem with solar thermal is that the sun shining doesn't align with when heat is needed. (Which makes sense when you think about it). There just isn't any good method of storing heat.
      If you are grid-tied and have net metering, the grid is your storage.
  3. FrankD | | #4
    If you like to make stuff and have a wall that receives a lot of winter sun, you could certainly build a large solar air heater and draw your ventilation air in through that. Design it with a bypass for warm weather days. Gary Reysa has some plans for low-cost solar air heaters on his website: https://builditsolar.com/Projects/SpaceHeating/Space_Heating.htm
  4. Expert Member
    Akos | | #5
    About the only thing solar thermal might make some sense for is heating a pool. Outside of that, add more PV panels. Even if those panels are driving resistive heaters, it will still be cheaper for the same BTU output as thermal panels plus all the bits to get it to work.
    Since you have a heat pump and if you want to take this on as engineering project, you can size a buffer tank that will be filled by the AWHP to shift some excess daytime PV into night time heat. You can control the speed of the pump feeding the buffer tank to adjust heat pump output to match excess solar. You might also be able to hijack the DHW mode to get extra hot water for this without effecting the operation for the rest.
    Same as thermal PV, the cost of this means ROI is pretty much never, but would be fun to play with.
    1. begreener | | #6
      This is what Harvest & SANCO2 are doing ...
      https://www.youtube.com/watch?v=u8PAkO70UFY
  5. rhl_ | | #7
    It seems like there are these solar PVT options where the thermal bit cools the panel off. My overall concern would be the ability to get maintenance given how dead the space is. I somewhat have a hard time believing that there isnt some version of this that makes sense.
      BILL WICHERS | | #8
      The problem is that the “version[s] of this” usually aren't economically viable. I think I’ve mentioned on here before that my work involves datacenters, which produce massive amounts of relatively low level heat. I have, for years, tried to find a way to somehow make that heat useful. I joke that we need a towel laundering facility built next door, but in reality the only thing I’ve been able to come up with is to use the waste heat to heat the parking lot so that we don’t have to salt or plow in the winter. I have megawatts of heat to deal with, but it’s too low grade to be very useful, which makes it uneconomical to try to recover, unfortunately.
      It’s not that it’s not possible to do what you’re considering, it’s just that there are other ways that are cheaper.
      DCcontrarian | | #9
      It makes sense when the availability of solar aligns with your need for heat. Akos in #5 mentioned heating a pool. Or when it doesn't particularly matter when you get the heat, there are lots and lots of solar kilns for drying wood for example.
      If you're off grid, or energy is otherwise expensive, it might make sense. Solar hot water might make sense for a summer cabin.
    3. LukeInClimateZone7 | | #11
      Rhl
      A specific concern I'd have in this case is that is that preheating water with solar thermal steals from the efficiency of the awhps, that is if it even works. Some unitary hpwhs, for example, shut down when inlet water temp is too high (say from a preheated buffer tank). Many central water heating systems have their own swing tank on the recirc for this reason, and even if it's a heat pump, it operates at a MUCH lower temperature.
      All this to say, stratification in a conventional DHW setup is critical to achieving anything like the rates efficiencies of the awhps unit. If you're able to switch back and forth from a solar thermal system and an awhp system, that might work better. But then economics would come in to play. Its starting to sound like a rube goldberg setup. It's all doable, and could be done cheap DIY, but then you're paying in patience and attention.
  6. Tim_O | | #10
    When you use solar PV and then use that power through your heat pump, you gain a whole lot of efficiency. And the solar panels are a LOT cheaper.
    The cheapest way to do solar thermal would be to buy some PV panels and wire them directly to a DC heating element in a water heater. You can get panels as cheap as $0.20/w these days. Cheaper if you buy used or blemished. Just do not try and use AC relays/switches with DC power.
    A solar thermal system is going to be $3-4000 just for equipment. And at the end of the day, stores maybe 10kw worth of energy. You can buy a 14kw battery for that price, which gets you 30+kw of heat out of your heat pump. A battery like that would let you take advantage of low night time rates or store energy from a PV system.
