Residential air curtain kitchen ventilation hoods
![](https://secure.gravatar.com/avatar/b40f3fd14a5c37aa53f2d552d9f75515?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
I don’t believe there are any commercial solutions at this time, but I found this interesting research paper: https://www.sciencedirect.com/science/article/pii/S1877705815027800
It seems like with the advent of tighter enclosures, air curtain hoods could be attractive because they could provide equivalent performance at a lower total cfm, which might reduce the cost of make up air solutions.
That is very interesting. It would solve an important problem in current air-tight homes. I had seen a video from Matt Risinger a few years back where he had the make up air at the back of the range. While this is not the same thing, I make the link that having air rising on 3 sides of the range allows for improved capture.
Usually in commercial applications the curtain is projected downwards
Thank you for the clarification. I did not see that mentioned in reference document and made an assumption based on limited information.
Your comments led me to read a bit more. I did not realize the issue was so important in commercial and laboratory settings. It is amazing to see how the effectiveness of hood vents has been closely studied.
Interesting article
https://academic.oup.com/annweh/article/54/1/78/152944?login=false
List of articles
https://pubmed.ncbi.nlm.nih.gov/24521068/
https://www.tandfonline.com/doi/abs/10.1080/15459624.2013.848036
Here's another residential study
