repair over-foamed window
![](https://secure.gravatar.com/avatar/960fd385d2d99c24f0ab40bf4ddaf03d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Sloppy window installer over-foamed all windows. Some frames bowed enough that glass is bulging. Am I right that they have to be removed and reinstalled, or is there a simpler repair? And that the worst few might be permanently damaged and require replacement?
Everyone who installs windows deals with this at least once or twice. The only solution I know of is to dig out the foam, screw the jambs into position and redo the insulation. I've found a keyhole saw to be the tool for the job. If you don't have flanges you can use a reciprocating saw.
For what it's worth, filling the gap entirely with foam has a negligible benefit over using just enough foam to air-seal the interior.
I should have mentioned that we do have nail fins...
