Tips for Removing Vinyl Plank Flooring
![](https://secure.gravatar.com/avatar/f979e98f0bee0b5ee7b2f25433a7d08c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Have to remove some glued down vinyl plank flooring, I anticipate this will be tedious and awful. Sub floor is standard spruce T&G plywood.
Any good tips?
I haven't done this but probably a glue scraper, which is similar to an ice scraper. Consider renting a wood flooring edge sander or even a drum sander to deal with stuck-on glue.
Most glues will let go if you apply heat from a heat gun.
As a last resort you can freeze the tiles with dry ice that will break the glues bond.
Planks sound like a newer floor but test older tiles and glue for asbestos?
https://www.youtube.com/watch?v=cwg6P64rRm0&ab_channel=PeterNguyen
Often older glues are dissolved by paint thinner, you get a puddle on the floor and work an edge with a scraper. Do it in nice weather when you can have the windows open, the fumes are no joke.
Newer glues seem to be polyurethan based and are pretty impervious, a heat gun will soften them though.
Often it ends up being a fool's errand to try and save the subflooring.
This is a section of floor from my last phase of renovation about 9 years ago that I am tying into a new addition. I have yet to break through and actually see how my new level floor will match up with the old existing floor compared to the reference points I used during construction.
I will try the heat gun, good idea.
