Removing and reinstalling a newly installed window?
![](https://secure.gravatar.com/avatar/31f02f75cfce555112c1e60fe0eda4a9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
One of the windows (installed with nails in the nail fin and caulk under the nail fin) is not plumb beyond the acceptable. It’s a picture window; so, there are no issues with operation. Yet, aesthetically it really cannot work. The top leans inward.
How complicated will it be to remove and reinstall? Will the mail fin survive?
I just don’t know whether it’s possible to fix it without removing and reinstalling.
For the record, what happened, I think, is that, while the window was plumb at first, the contractor banged too hard on the nails, and the ZIP R foam got compressed. At least, that’s my diagnosis.
A very distressing situation, of course. These are brand new, expensive windows.
Also, it’s beyond me why Marvin would indicate, in the insulation instructions, the use or NAILS, to then have a page on their website that explains that SCREWS are… BETTER. I had the contractor switch from screws to nails, so as to follow the “manufacturer’s instructions.”
It's usually not that hard to remove a window. Take out the nails carefully using a cat's paw-style nail remover. The fin will get a little beat up but you can use a scrap of wood to protect it. Then run a kitchen knife between the fin and the wall to loosen the sealant; it might not be fully set up yet anyway.
Thanks! That’s reassuring!
If the trim and siding haven't been installed this isn't a big deal, it's pretty routine. I'd be more worried about getting the opening plumb.
Thanks! The opening was plumb. I wonder if it is now though.
