Recommended insulation level in commercial buildings
bHqUcamKme | Posted in Energy Efficiency and Durability on
What are the recommended R values for insulation in a commercial building that is conditioned? I am in Spencer, Iowa so that would be Zone 6.
  1. GBA Editor
    Martin Holladay | | #1
    Curtis,
    You should contact your local building code official to determine the code requirements in your local area.
    According to the 2006 IRC, residential buildings in Zone 6 need a minimum of R-49 ceiling insulation, R-20 wall insulation, and R-30 floor insulation. Whether the building is commercial or residential, I wouldn't recommend less insulation than the code minimum.
    More is better.
  2. Riversong | | #2
    The IECC standards are in Tables 802.2(1) through 802.2(7).
  3. Riversong | | #3
    This link is to a DOE manual for inspections for the commercial provisions of the IECC: http://www.energycodes.gov/training/pdfs/iecc_com_wb.pdf
  4. Armando Cobo | | #4
    Look at the 2009 IECC, Chapter 5. Table 502.1 gives you the Building Envelope Uvalue for a particular building method (metal, metal framed or framed). Table 502.2 gives you the Rvalues for same. You should be familiar with the whole Chapter 5 as there are many other parameters and requirements for commercial buildings.
  5. user-788447 | | #5
    Curtis,
    Ideally a developer thinks in terms of an energy goal and then determines the R-values, air tightness, window specs, and mechanical specs needed to meet that goal. PassivHaus principles are being applied to small to mid sized commercial buildings (office and school buildings) in Europe.
