Recommended gas furnace for 3550 square foot house
![](https://secure.gravatar.com/avatar/48f7289e6b3ecddd9059b829257133bf?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fv.png&r=g)
Vissu
| Posted in Energy Efficiency and Durability on
Please let me know recommended gas furnace for 3550 square foot colonial house in Detroit area
Find a good local installer and follow his advice. In most cases a 92% + furnace makes sense.
Vissu,
Step one to designing a heating system -- or specifying a furnace -- is to perform a heating load calculation. Here are links to articles you should read:
Who Can Perform My Load Calculations?
Saving Energy With Manual J and Manual D
How to Perform a Heat-Loss Calculation — Part 1
How to Perform a Heat-Loss Calculation — Part 2
There are at least three aspects of selecting a furnace: brand, features, and size.
Regarding features, my prioritized list would be condensing (first digit of efficiency is 9), ECM-type blower motor, and two stages.
Regarding brand, my advise would be to select a contractor you trust and use whatever that contractor prefers. The hard part is finding a contractor you trust. After you read the articles Martin mentioned, you will know what question a good contractor should be asking you. If you call a contractor, and the only question they ask is square footage, or the label on the existing furnace, keep calling others. If this is a replacement and they ask about recent natural gas bills, that would be a good sign.
Regarding size, even if the contractor asks the right questions to calculate it properly, you cannot necessarily trust the recommendation. Contractors typically have a "make sure you don't undersize" mindset rather than a "size it right" mindset. If this is a replacement, use the method described by Dana Dorsett at https://www.greenbuildingadvisor.com/blogs/dept/guest-blogs/out-old-new to cross check the recommendation.
