Recommended Finish for Slab that is to be polished after the framing is complete?
idahobuild | Posted in General Questions on
Hey,
Question about concrete finish that the concrete crew should shoot for to later achieve a Gloss Level of 2 and an Aggregate Exposure Level of B.
The concrete sub won’t be providing the finish on the concrete. Are there specifics that I can provide to the concrete sub to make the outcome provided by the polishing crew more accurate?
Thanks.
  1. jberks | | #1
    You can ask the placers to float the slab well to get a good cream on top. That pushes the large aggregate down a bit, and leaves more salt and pepper at the top.
    Also. It'll be easier on the grinding/polishing crew if the placers power trowel the slab. The smoother the surface, the less grinding is needed.
    1. idahobuild | | #2
      Awesome info. Thanks Jberks. I've asked the GC to check with the sub on those two things.
