Recommended concrete moisture levels for spray foam
![](https://secure.gravatar.com/avatar/e7a61ad9b2d7777eb7f6f7d6b20b4c33?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I have a poured basement poured 6 months ago bituthene on outside walls. House recently dried in heat in basement has been on for 2 weeks. Moisture content 70% done by drilling holes and placing probes in concrete. Some surface readings done by laying a moisture meter on surface of concrete as low as 30%. Basement stud walls in place ready for spray foam. At what moisture content (and how should it be measured) can closed cell spray foam be applied?
Just to be clear, you're talking about moisture content as a percentage, and not the relative humidity inside the concrete, correct? If so that's very wet still.
Which probes are you using?
Yes moisture content as a percentage using a moisture meter. We used a moisture meter that rests on the surface of the concrete and had readings from 30 to 58% highest readings at
The top of the wall. Borrowed a moisture meter from flooring contractor they use before installing floors where you drill about an 1/2 to 1 inch
And place a probe and reading 70%
