Recommendation for continuous run bath fan with humidity sensor boost
My Hawaii house is a vacation rental and there is a bathroom with no window. We have a bath fan timer which is selectable from 10-60 minutes. But after many years of being fine the bathroom is starting to collect moisture after several people have showered. Since we are a humid climate and the house is completely open, we have a Panasonic Whisperquiet running in the neighboring hall to pull air through the bedrooms which can get stagnant because there’s only windows on one side.
For this bath I’d like to have another continuous running fan, but with an automatic humidity boost. I swore this was common but am having trouble finding one. The Panasonic I found it’s either/or. All the time or timer or humidity activated. My concern with being purely humidity activated is that the sensor may fail when we’re not here. I found an AeroPure, but that was about it. Any suggestions?
BTW there are no typical issues with humid climates such as needing dehumidification to prevent condensation from air conditioning. The house is completely un-insulated, with no HVAC system, and the windows are never closed. I’m simply trying to move moisture out of the bathroom more quickly & consistently.
Thanks!
Something like this?:
https://www.homedepot.com/p/Air-King-80-CFM-Dual-Speed-Humidity-Sensing-Bathroom-Ceiling-Exhaust-Fan-E80DH/203546941#product-overview
80 CFM Dual Speed Humidity Sensing Bathroom Ceiling Exhaust Fan
by Air King, $152
The dual speed model will run continuously on low speed. The integrated humidistat senses the humidity level of the room and boosts the fan to high speed when the humidity level rises above the preset level. When the humidity level falls below the preset level, the fan will return to low speed. The fan can also be activated to high speed through a wall control switch or timer.
Nah, the Panasonics can do this. It's in the modules and/or switches you buy as add ons, and then there is a very specific way you need to wire it. Panasonic does NOT make it easy to figure this out...
https://www.leviton.com/en/products/residential/fan-controls/fan-speed-controls/humidity-sensor-fan-control
