Recessing concrete stem wall for zero-threshold prior to choosing door manufacturer
![](https://secure.gravatar.com/avatar/5b049f0b784177cf332dca2d976fe1bc?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hi all, I’m planning to recess the top of our stem wall by 1” to allow for a zero-threshold patio door, but not sure what length to recess. We’ve engineered the framing plan for a 10’ wide opening onto the patio, allowing for a 72” double hinged door, plus 2 sidelights. We haven’t picked a door manufacturer and I understand the “standard” sidelight widths can vary a bit.
Is it ok to just recess the 10’ length of stem wall, and just order a custom door package later so it fits? Or is there a common standard width for this design (double 36” doors +2 sidelights)?
Thanks! I’ve attached the relevant framing elevation.
Adam
Rough openings for typical exterior doors are usually 2 1/2" wider than the door leaf(s) and 2" taller than the door leaf. Sidelights come in many different widths so you should really just decide on a door before pouring your foundation.
Ok Thanks Michael!
