Re R Rating on Loose Cellulose
![](https://secure.gravatar.com/avatar/09977768db479e80284d744eafd835b4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I know R rating is 3.7 per inch for Cellulose, what is it if roof is filled with 75mm thickness of Cellulose? or what is formula. Would not think it would be 3 times, as never heard of higher rating over 6
Thanks Colin
Colin,
75 mm = 3 inches
R-3.7 per inch x 3 inches = R-11
R-11 isn't much. Many builders are aiming for R-60 these days.
Colin: In case you missed it in Martin's response, the R value is PER INCH. 10" = 10(3.7), etc.
