Re-coating a previously coated Elastomeric Roof Coat on Flat Roof
![](https://secure.gravatar.com/avatar/d15f5d428d83ef69a1038fbb6af3bad7?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fv.png&r=g)
Good Evening:
My name is Victor. We purchased a mid century modern home with a flat roof that the previous owner (who told us) coated in its entirety with elastomeric acrylic coating.
It is showing signs of wear in areas and I want to re-coat before the winter rains.
I would much rather prefer to re-coat with silicone but I have researched everywhere but couldn’t find a resource confirming whether a silicone re-coat will adhere to previously applied acrylic elastomeric coat.
I am hoping someone from this great site would be able to answer my question?
Can you re-coat a previously coated acrylic elastomeric flat roof with silicone?
thank you in advance for your reply.
Hi Victor,
I'm not a roofing expert, but Henry has a tech bulletin that probably arose from these type of questions. It's probably cheap enough to buy a gallon and test on your own roof to be sure. I'd give their tech support line a call, they'd be able to tell you quickly.
[email protected]
800-486-1278
https://henry.com/fileadmin/pdf/literature/HE887HS_Silicone_Adhesion_Test_0515.pdf
