Roofs and Walls: Interior vs. Exterior Insulation
![](https://secure.gravatar.com/avatar/85c969b0fc45e68d6cb37ef2eec5958b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
I am curious if anyone knows the reason/science behind why the ratio of internal to external insulation is smaller in walls then a roof? For example, in my zone, Zone 6 about 51% of the insulation should be on the exterior of a roof vs 36% for a wall. Is it because walls are less likely to have moisture build up due to condensation vs a roof?
Erik,
You have double-posted your question. To see an answer to your question, go to the GBA page where you also posted the same question: https://www.greenbuildingadvisor.com/article/combining-exterior-rigid-foam-with-fluffy-insulation#comment-237381
Thanks for your response as to why the ratio requirement is greater in roofs.
It’s nice to know the reason behind a regulation.
