Raising an exterior door frame
![](https://secure.gravatar.com/avatar/24115f53ab37e6bb5b212fbd868862d9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
I live in climate zone 4A and have a 44 year old, completely non-insulated slab (on grade). I have a big project coming up so I want to seize the chance to insulate on top of my existing slab. There are plenty of articles on GBA for how to do that and I’m pretty sure I can handle that part. There is one small detail that NOBODY ever talks about in these threads anywhere on the internet. My entry doors have aluminum thresholds 1-1.5″ above the slab. If I go ultra minimal and do 1/2″ rigid foam and another 1/2″ wood, I have basically no room for the flooring.
Intuition tells me I need to re-frame my entry doors to make them 1″ higher (or however much I decide). I understand the framing part but that information is super easy to find. The information I need is the threshold specifically. What should I do to lift the threshold so I can reuse my existing doors and have it be done right?
William,
Run the foam and sub-flooring through under the door frame and theshold to the exterior.
William,
It sounds like you have a pre-hung exterior door. The aluminum threshold is attached to the jambs.
You will need to:
1. Remove the interior and exterior casing (trim).
2. Remove the screws or cut the nails (with a Sawzall) securing the door jamb to the rough opening.
3. Remove the door (jambs, threshold, and all).
4. Re-frame the rough opening (or, if there are no structural reasons preventing you from doing so, remove some of the bottom of the header with saw cuts and a chisel) to allow the door to be reinstalled.
