Rainscreen behind cedar shingles
steveworks | Posted in Energy Efficiency and Durability on
I’m very comfortable using strips of wood ( usually ply) behind lap siding and it SOP for me. I haven’t done it with shingle yet. Can I assume that I nail up the strips horizontally and leave some gaps here and there so air and water can flow? Any detailed drawings or better instruction that i can check out?
I could also go with cedar breather ( spun) but not sure if that’s more expensive or not. I plan to try and push for using poly-iso boards on the exterior if I can get the client to budget for it.
Thanks
  1. GBA Editor
    Martin Holladay | | #1
    Steve,
    Either approach will work -- Cedar Breather or horizontal furring strips. Horizontal furring strips require a lot more labor to install than Cedar Breather.
    I wouldn't worry about drainage. You're not talking about much liquid water; any water that gets past the shingles will rapidly evaporate.
  2. steveworks | | #2
    Thanks Martin
    I'll probably go the Cedar Breather or Home Slicker direction. Putting up horizontal furring will just suck up too much time and drive me crazy also.
  3. dankolbert | | #3
    Unless you're going with a pretty big exposure (7" or more), horizontal strapping is a huge PITA. You end up with more wood than air space with a 5" exposure.
  4. user-869687 | | #4
    Steve, if you did install exterior polyiso, then it would make sense to use the horizontal strapping rather than cedar breather, just so the shingles can be nailed into strapping. A much smaller number of screws will then penetrate the insulation, to hold on the strapping.
