Radon mitigation system
user-438846 | Posted in General Questions on
I’m putting in a radon system plan to run a pipe up through the garage.
I want to confirm it is ok to run the pipe between the wall of the house and garage.  (inside the wall to the garage attic) then out the roof?  Is this acceptable.  I see numerous examples that run the physical pipe on the garage side of the wall up to the ceiling?  Thanks for the feedback.
  1. GBA Editor
    Brian Pontolilo | | #1
    Hi Derrick.
    If I am understanding your question correctly, I don't think there is any problem with what you are aiming to do. Have you read this: All About Radon?
