Radon sealing with thermal break insulation
![](https://secure.gravatar.com/avatar/195d3341ea0d987ccb7d4d868b7a0dc7?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
New construction in S.E. Wisconsin with partially exposed walk out basement. The concrete floor will be insulated and also have thermal break at edge. I would like to install a passive radon system with 4″ pvc extending up through the roof.
I am looking for details with continuous insulation from under slab up to and including both the stud wall at exposed side and 2×4 furred out walls against the poured concrete walls while locking in potential radon under the floor to be vented outside.
