Radiant barrier for garage
![](https://secure.gravatar.com/avatar/de123803f8a08237c254f3939bd888d1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Hi , I am building a new home Phoenix AZ , main house will be SIP’s , my 3 bay garage will be on the S/W cnr and will be traditional stud , radiant barrier osb external and then drywall internal , I will have low level vents around perimeter of garage and then ridge vents ( 6ft of available ridge ) I will be leaving a permanent opening thru garage ceiling to access the storage area above thus allowing free flow of hot air to ridge , the walls/roof will be treated same as walls
my questions are , will the natural flow of air caused by heat rising be enough to keep garage to same outside air or should I introduce mechanical assistance , also will I need to create a path for hot air between osb and drywall up through wall plate and along roof void .
many thanks
David
and can you please tell me how do i search for previously asked Q n A so I dont go repeating myself on questions , thx
David,
Q. "Will the natural flow of air caused by heat rising be enough to keep garage to [the] same [temperature as the] outside air?"
A. Probably not.
Q. "Can you please tell me how do I search for previously asked Q and A?"
A. At the top of every GBA page is a search box. For this question, you might type "cooling a garage" or "hot garage" or "garage fan" or "garage AC." Try a variety of search terms, with and without quotes.
