quote for installing
i would like to no if the material is supplies.just to install the z bar and styrofoam .onwall and if i have to charge for c chanel and slope c chanel around door and windows…the project to do is about 14000 sqf and the scalfolding is in place….how much i should charge by the square footages…also install hardi.drip cap.and trim around windows and caulk..and backing for exteriour railing.on a building of 128 unit thanx a head Daniel..
You'd like a quote? How about:
"Insanity is doing the same thing over and over again but expecting different results."
This is often misattributed to Einstein or Ben Franklin, but was first found in print in a 1983 book by Rita Mae Brown.
