Question about dense-packed cellulose wall insulation coupled with a service cavity in new construction
![](https://secure.gravatar.com/avatar/b4903579db56e4b1912f8eda3d8686c5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
Hi all,
I’ll be starting work on a new house this summer in Kentucky (Zone 4a, mixed-humid climate). My plan is for a stick frame house with 2×6 walls. I will be using ZIP system as my exterior sheathing and air barrier, and plan to use dense-pack cellulose in the stud cavity. I really like the idea of including a wall service cavity to account for any future work to the house, but I am a bit unsure as to the best way to install the service cavity and maintain the integrity of the insulation. As I see it, I have two potential options.
Option A: Have the dense-pack installed behind Insulweb, then place horizontal strapping across the stud face.
Option B. Have the dense-pack installed behind Insulweb, then place OSB on the interior stud face, then create my service cavity with strapping.
My instinct is that Option B would be more resilient over the lifetime of the house, but I also realize that I may be introducing problems by placing a vapor barrier (in the form of OSB) into the inside of my wall stackup.
Any thoughts would be greatly appreciated!
Will,
OSB is a vapor retarder with variable vapor permeance. It is not a vapor barrier. Installed as you propose in your climate zone, it won't cause any moisture problems.
Here is a link to an article with more information on this topic: Service Cavities for Wiring and Plumbing.
