Material for Skirt Board
![](https://secure.gravatar.com/avatar/c6331c06915860aeea372d6e10054a30?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
Does anyone know of a PVC free skirt board material. Moisture and insect resistant but firm for potential impacts at grade. Project in upstate NY. Thanks
https://truexterior.com/
Isn't it a little soft for a skirt board? We use it for trim around windows and siding.
Just wanted to make sure you were aware of it. It’s an option for non pvc ground rated contact material. I haven’t taken a weed wacker to it personally, it may or may not be tough enough depending on the impacts you are anticipating.
Cellular PVC and TruExterior poly/ash are the only board-like products I know of that are rated for ground contact. Neither will hold up to a lot of direct abuse by weedwackers etc., but you should have a zone around the house without vegetation anyway, to help with bugs/weeds/fire.
If you want a more durable solution, I have seen stainless steel sheet metal used for skirting. My personal favorite is to install expanded metal lathe and parge-coat it with cementitious or synthetic stucco (Styro Tuff II or similar.)
What about Hardie Trim fiber cement products?
Hardie in ground contact is bad idea in snow country, once it gets wet and freezes, it turns into mush.
Some of the adhered thin stone/brick veneers can be installed pretty close to the ground if there are pavers and they take plenty of abuse. Not cheap but you also don't need a whole lot.
We used a lot of this for exterior trim ... https://modern-mill.com/trim/
