Problem with flashing details at inside and outside corners (3 inch foam)
kenorakq | Posted in General Questions on
I’ve stripped my exterior walls to the plywood and am about to install the metal flashing at the bottom of the wall… with 3 inches of foam and 3/4 inch furring strips and a Hardieboard type horizontal lap siding to be added the projection of the flashing is enormous.. at 4″1/4 inches plus a 1″ drip edge lip.
Problem is at inside and outside corners: I can’t figure out how to miter these complex curves into a continuous flashing. Is there a video here or on youtube that gives some insight?
I’ll post a picture shortly to illustrate… thanks
    MALCOLM TAYLOR | | #1
    Tim,
    I'll try and walk you through a simple method with these sketches.
    Starting with the outside corner.
    - Cut the flashing as shown in the top-right sketch and bend down the end slightly along the 45 degree dotted line.
    -Cut the opposing piece of flashing at 45 degrees from the corner as shown in the bottom right sketch. Install in a bed of caulking on the first piece you cut.
    Inside Corner
    - Cut the flashing as shown on the top left sketch, and bend up slightly along the 45 degree dotted line.
    - Cut the opposing piece of flashing at 45 degrees from the corner as shown in the bottom left sketch. Install on a bed of caulking on the first piece you cut.
    Because of the length of the overlaps you may want to secure them together with a short metal screw.
    MALCOLM TAYLOR | | #2
    Tim,
    Another approach is to use U-shaped perforated flashing to cover the whole thing.
  3. kenorakq | | #3
    Thanks for the insight..I'll give it a shot..
