Preferred subfloor material and adhesive for minimum off-gassing?
![](https://secure.gravatar.com/avatar/3f85e5102da48c635b3467017cfc2ce3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
Does some subfloor and adhesive rate better than others for minimum off-gassing? Regular OSB is the least expensive, but are some brands better than others? and the same with subfloor adhesive; is there a healthier brand for indoor air quality or is it all about the same?
I used Huber Adventech flooring and Loctite PL Premium adhesive because both products are rated as emitting low levels of chemicals. There might be better choice, however.
